dontarantini
- Messages
- 10
- Reaction score
- 0
- Points
- 1
Hey Guys,
I've suddenly got a problem with the bike out of nowhere.. I was hitting 70, cruising strong.. suddenly the engine starts making some strange noises (metallic possibly) and then can't keep up the speed.. the engine is sputtering and running very unevenly.
I stop at a gas station, shut it off for a minute or two and decide to try to keep going. Figure this out.. it went back to normal.. it got me back home that night just fine. It even got me to work the next day, unfortunately on the way home from work it failed and it wouldn't run right again. It just won't go above 2-3k rpms or stay idling.
I just recently did rings to the engine a couple weeks ago, so I decided to check compression, both have 90 lbs (kinda low?). So I put a capful of oil down the sparkplug hole of each cylinder and tried running it again, it ran exactly the same as before.. can't be the rings. I've taken the carbs apart twice and cleaned them, put a gas-soaked rag in the air filter's place, nothing changed.
Then I tried removing a carbon brush from the alternator.. bingo! Now the bike starts up and cranks right through the 2-3k barrier to any rpm I want, and it sounds pretty decent while doing it, but it still won't idle and that isn't exactly a way of fixing the problem.
Anyone have any clue whats going on? It seems electrical but where could the problem be? Also, could a valve/valves be causing the low compression? How do I check to see if theres something wrong with the valves?
ANY help would be appreciated, can't wait to start riding again.
