XS650B 1975 - Bracket, Batt Box 447-21149-00-00
Niels B
XS650 Junkie
XS650.com Supporter
North Florida
anyone have a couple of brackets for the battery box on a 1975 xs650B or know where i can get them? the once supporting the air cleaner housing. or if possible just give me the dimensions and i can try to make one myself - main issue is the angle between the bracket and the rubber support for the batt box, hard to determine on a picture
  • Bracket batt box xs650b.pdf
If you give me a day or so, I should have one ( a set). This will fit in a USPS priority box too. I will let you know soon.
Edit: Found some. PM me for more details. Bad picture but the rubbers are in the too.
fantastic - i have search all the web pages i can possible think of - but with no luck :)
Not sure if these came off the XS650B model tho. Is there a difference? That's the question. Look the same.
here is a few pick of my recent works, HD 1942 45cuin flathead (color is like a 1930ies model), the '77 Honda CB750F2 is next project and then the '75 XS650B - or maybe i'll do the XS first as it's in a better condition engine wise :)
For help with searching for stuff like this, I really like the Partzilla web site. Start out here on this page and choose your year .....
https://www.partzilla.com/catalog/yamaha/motorcycle
.... then your model from the "Year" page .....
https://www.partzilla.com/catalog/yamaha/motorcycle/1975
..... and finally, the drawing for the part you seek. In this case, the battery box mounts are in the "Side Cover Tool ...." drawing .....
https://www.partzilla.com/catalog/yamaha/motorcycle/1975/xs650b
https://www.partzilla.com/catalog/yamaha/motorcycle/1975/xs650b/side-cover-tool-tx650a-xs650b-c
Click on one of those front mounts (#2 or #3) and the page for the part gives you a list of the other models it came on. In this case, it appears those mounts were used on the '74 through '83 models, right up until the end of production .....
https://www.partzilla.com/product/y...?ref=2bbb9a793653cd4fa935ca375c1d427ce89922a2
great site - unfortunately this specific item isn’t available any longer - however the fitment info help on the search as it can be expanded to a larger array of models. Thanks
