Here's the final products by the way!
The valves that have the same side rim height are exhaust valves, which I found interesting that he didn't need to cut them more, considering it's usually exhaust that pits more.
The side by side valve angle shots are just for my records, I wanted to see how much he cut out of the surface. Seems kinda thin, but he told me he picked the best valves out of the eight that I gave him. I believe it, because I labeled the head# on each valve from the motor they came from, he seemed to have used a mix of each. The side by side is also a cut valve beside a non cut valve. Really just wanted to compare angles.
I have everything a dawn dish soap bath, and boiled water to pour over them to release as much media from blasting as I could. They're clean, but need a good pressure was, and maybe another hot water rinse to really make me feel comfortable.
Altogether, I'm happy with how it all came out. I may clear coat the motor when it's assembled to retain the factory appearance without it oxidizing too much.
