neither he or you are able to to establish whether or not there is actually a fuel delivery problem or not ?
It's established it's either fuel delivery or a compression problem.
The engine ran well about a month ago when I was actually riding it around, at this point in time, both cylinders fired fine. And before I obtained the bike, it was sitting in a barn for at least 10+ years without maintenance.There's no guarantees when working on old motorcycles. However, the pilot circuit/idle circuit/low speed circuit is known to cause a lot of problems.
When was the last time your engine ran well, or did you just buy it? What is the history of the engine?
All of that was cleaned, I was very vague on the description of the cleaning we did, although we went very thoroughly in cleaning it. (Taking out those parts you described)As you've discovered, there's more to cleaning carbs than just cleaning the outsides and any areas and parts you can see in the float bowls. You have to clean the internal passageways and jets, the paths the fuel uses to get from the bowl into the main bore of the carb. From your description of how gummed up you found things in your float bowls, I would say a full strip and cleaning is required. That means removing the main and pilot jets, the mix screw and it's associated parts, and last but not least, the needle jet. Many overlook the needle jet and that's a big mistake. It can and does get terribly gummed up.
The bike was never run with the carbs being gummed up. So we had to take them off and clean them before the bike would even start. It may partake to you guys that I may be inept or stupid, though I find an interest in motorcycles, this motorcycle is the first motorcycle I've ever had, so I actually don't have much mechanical skills, but I understand what you all have been saying mostly.Apparently you didn't read the part about him looking in the float bowls and finding them all gummed up. He was running the bike like that until it up and quit. That pretty much guarantees he has sucked all kinds of gunk into the passageways and plugged things up. I was taking carbs apart when I was 14. Are you saying today's youth are inept, stupid, and have no mechanical skills? Sounds that way.
I just checked the spark from the spark plugs and they seem to be sparking fine, although I have about 1/6 of a tank of my 3.9 gal tank. I will be filling up my tank tomorrow, due to me winterizing my bike since up in Wisconsin it's pretty cold
Alright so I swapped wires, putting the left side spark plug connector on to the right side, started up, and still the right side warmed up, and not the left. I'm guessing both leads are intact and working. So I'm not sure what to do next... :/
I will not be able to check the compression until my dad's friend finds his compression tester.
Until then you can stick your thumb on the spark plug hole while the motor is turning and see if you feel pressure.
Remove the vacuum line from the LH intake manifold, block off the port on the manifold. (short piece of rubber tube and a bolt work fine) run the petcock in the prime position. Does that change how it runs?
We didn't put any new parts into the carbs, just cleaned them, the float heights were at the correct height. (Probably should of bought a kit to rebuild it.. :/)When you worked on the carbs did you remove the float valves and change the O-rings or install new float valve bodies? those O-rings are almost always rock hard and allow fuel to bypass the valve flooding the cylinder. did you set float heights?
