1. Dismiss Notice
    Dismiss Notice
For Sale - Yamaha XS750 Flattracker!
Discussion in 'Classifieds' started by bt24, Feb 27, 2017.
  1. bt24
    bt24 XS650 Addict
    IMG_7700.JPG IMG_7702.JPG IMG_7705.JPG IMG_7706.JPG IMG_7703.JPG IMG_7704.JPG
    New Champion copy Yamaha 750 Twin for sale.
    Fresh build, only break in time on new engine build, almost everything on this build is brand new.
    $7,800. OBO plus shipping.
    No trades, Possible delivery.
    New Champion Yamaha XS750 Build/Parts sheet
    New Chromoly tubing frame built in a Champion XS Yamaha Frame Jig.
    New Tapered Steering Head Bearings
    Rebuilt GSXR 750 forks & Triple clamps
    New Vortex Johnny Murphree bend 1" taper bars
    New Pro Taper Bar Risers
    New Pro Taper grips
    New Motion Pro Turbo Throttle
    New Motion Pro 2 into 1 Throttle Cable
    New Kill Button
    New MSR Adjust on fly Clutch & Perch
    New Clutch Cable
    Works Rear Shocks 1/2 season old
    New Excel Wheels 2.50X19" Front/ 2.50X19" Rear
    New HD Stainless Spokes Front & Rear
    New Maxxis Tires Front & Rear
    New Barnes Hub Front
    New Barnes Hub Knock Off Rear
    New Streamline rear disc with New billit aluminum carrier
    Nissin Brake Caliper with New Brake Pads
    New Stainless Steel Braided Brake line
    New Stainless Brake fitting
    New Nissin Master Cycinder
    New Billit Brake Pedal
    New Billit Brake Ped/Mastr Cyl plate
    New 520QR Tsubaki Chain
    New Billit Axcel/Chain Adjusters
    New Rear Axcel
    New Swingarm bolt/bearings
    New First Klass/Bates foot peg rubbers
    New foot peg blades & mounts
    New 750 Fiberglass Tank & Seatbase w/ Seat
    New 90 degree K&L Fuel Petcocks w/New fuel line
    New Engine parts list
    New Billit Cam Covers
    New Nuts & Bolts
    New Billit Engine Mounts
    New All Gaskets
    New All Seals
    New Reed Type PVC Valve Engine Breather
    New Oil and Lower Oil Sump Filters
    New Axcel 8.8 Coil Wires/Caps
    New PVL Ignition and Coils
    Norris 1/2 Mile Cam
    New Tsubaki Cam Chain
    New Cam Chain Guide
    New Cam Chain Tensioner Pivot Arm Assembly
    New EBC Clutch Plates Steel & Fiber
    New HD Clutch Springs W/Allen bolts, aluminum spacers
    New Clutch Thrust Bearings & Nuts
    New Clutch Long Pushrod w/ Bearing
    New Clutch Push Housing Assembly
    New Kibblewhite Racing Springs w/Titanium Tops
    New Wiesco Yamaha 750 Piston kit
    New LA Sleeves
    New RD 1mm over Exhaust Valves
    New RD 1mm over Intake Valves
    New Bronze Valve Guides
    New 3 angle cut valve job
    New hand ported Intake & Exhaust Head
    New (2) 38mm Mikuni Round Slide Carbs
    New (2) Billit carb Intakes
    Jemco High Exhaust (Ceramic Coated)
    New (2) K&N Air Filters
    Stock Rods, Crank Bearings, Oil Pump, everything was checked for wear and runout.
    Bryan Trippe
    bryantrippe@msn.com
    Albuquerque, NM. 87124
    Cell: 505-400-7244
    TwoManyXS1Bs likes this.
  2. pago cruiser
    pago cruiser XS650 Addict
    Lord, that is sweet!:cheers:
    Is that a Champion swingarm? It looks way different than the Mule version - and it looks like the chain clears the shocks by a goodly amount.
    GLWS.
    bt24 likes this.
  3. bt24
    bt24 XS650 Addict
    It's a Champion copy, the chain is fairly close to the shock but the photo does make it look far away though!
    I'll have to take a look at Mules, are his a Champion copy also?
    Thanks for looking,
    Bryan
  4. Infantilebehavior
    Infantilebehavior InfantileBehavior
    Beautiful bike man....
    bt24 likes this.
  5. racerdave
    racerdave ^ Gone not forgotten ^
    Very nice. Good luck with the sale. Is the case beveled for looks only? total loss ignition?
    bt24 likes this.
  6. bt24
    bt24 XS650 Addict
    The case is beveled so you don't drag the case in the dirt. It's not a total loss system, there is no battery. It's a CDI system just like on a dirt bike, a PVL brand Ignition.
    Also there is no flywheel, no kick starter or kick starter shaft, gear or spring.
    It's a bump start, I have to put a remote starter hole where the flywheel is so you can use a remote starter to fire it off.
    Thanks,
    Bryan
  7. pago cruiser
    Don't mean to crap in your thread...
    but you asked.;)
    I don't think the Mule is a copy of the champion, but it is similar. But yours looks like it has more shock to chain clearance. With the YSS shocks I was trying to run, it would have been an interference between shocks and chain in anything other than a static mode. I saw you have Works Shocks - I talked to them today, and they indicated they can provide a shock with an offset base. How much? I hope to find out tomorrow.
    Love that left side cam cover.
    Now back to a really cool XS for sale....:D
    bt24 likes this.
  8. racerdave
    Knew that on the case, doesn't look like enough room for any flywheel, thats why I asked about total loss. Surprised you didn't move shift to right side? Regardless great looker.
    bt24 likes this.
  9. bt24
    bt24 XS650 Addict
    No worries about the thread, I could take a picture at a different angle and measurements of the swingarm if that would help you with your shock selection? Just let me know.
    Bryan
Share This Page
