yellow tube
motorbreath
Dubuque Ia
this yellow tube thats connected to the petcock goes down to the carb are and i was wondering what i should do with it because i got a new bobber petcock for my new tant and theres no second connection on the petcock 20100829182035.jpg so should i cap of the bottom part or what?? :confused:
THat is the vacuum line. The original petcocks are vacuum operated so when there is vacuum in the carb manifold the petcock opens and lets gas out. If you have a regular petcock then you need to cap that vacuum barb on the manifold. Make sure no air can leak past it or you will have major problems.
A tire valve cap would probably seal it up pretty well.
I run a piece of hose between the carbs. Seals the vacuum and is supposed to help balance the carbs induction pulses. Can't prove it by me but my bike runs extremely well.
A tire valve cap is way to big. Get the right size at the parts store.
