Hi there
I've done a search and I have a manual (It's in one of twenty cardboard boxes, possibly) so be gentle if this is a much answered question.
The bike fired up and after a while the revs went through the roof. Closer inspection showed damaged cables. (As the bike hasn't run in five years I am relieved not to have to spend the summer poking pipe-cleaners into every carburettor orifice.) I can get the cables online but I was curious to see that there was a "left" and "right" cable listed. I expected two cables, but not for them to be "handed". They are £26 each plus postage so I thought I'd get the old ones off and see what was involved in making up cables or salvaging the bits I have.
I was surprised to find that they are different - and not just in length. I would have thought that they would be the same.
Anyway - the LONGER one was one the right-hand-side which threw me.
SO
1. Has the previous owner fitted them incorrectly? Which goes where?
2. Only the sleeving is damaged. It's completely broken through in a couple of places. Should I use all the old bits and just replace the outer? The inner seems fine.
3. Should I do as my conscience tells me and get all new bits? (I'll have to use the angled bit in first photo.)
4. From lurking around the forum I suspect there is a "one into two" cable used on other years. Can I use one of these? It looks like it would all work fine if I did.
Throttle End
Carburettor end
Dave
SO
Throttle End
Carburettor end
Dave
