Street Tracker in works!
coneeng
Los Alamitos, CA
This started life as a 78 model but I think it was last used as a mooring anchor for jon boats when hillbilly handfishin'.
Here's a couple shots of the beginning of it's journey from the depths of despair...
Removing all the broken, rusted crap and giving it a good bath really cleaned the old gal up!
Sizing up the rear fender and seeing how this tank would look. Federal Truth in Advertising laws required relabelling the tank.
After consideration, there is no way that stock subframe is going to work.
I got to be honest, I am lucky enough to have some great friends do some, ok most, well actually, virutally all the heavy lifting on this build. But it's my design! LOL
Benderwerks in ATL, GA is doing most of the fab work with a special assist from Shop 102 in Kennesaw, GA on the subframe. The engine and electrical work will be handled by Atlas-Cycle in Marietta, GA.
Here's a look at the subframe work.
Here's where we are at now.
Got the 19" rear wheel conversion set up. Only has old 19" street tires for now, real dirt track tires will go on when the time comes and they will look much wider. Got the bars on and Hammerhead shocks. And the rear fender of course. Still working on deciding what to use for a tank. Several options in mind.
Next step finish the shock mounts. Then the motor to goes back in and to begin fabbing the custom exhaust. Going to be a SS 2-1 with several muffler options that can be changed out pretty easily.
How did you make the bend for the frame loop? I've been searching for someone in my area for months and no one can do it. Is it 3/4" tubing?
Looks like a mid 70's KZ400 tank. You're not advertising, right?!
I'm trying to figure out what the Kawi was off originally. It was just sitting on a shelf and looked much better than stock! Also going to try an early yam mx to see which I like better.
Naw, that was a feeble attempt at humor...
