EvenmoreXS
1981 XS650
Question? Do I need to take the weight off the swing arm before I use this steel rod to push out the broken pivot bolt, or will it be fine to push it out. I would then use the new pivot bolt to slowly push out the steel rod. That way there would always be something in the swing arm during the process. If i do need to, then I would just put a jack under it and lift it just enough to put most of the weight on the jack. Otherwise I will just go ahead and do it.
Reason for asking........wife drove off with my jack in the jeep. I'll have to wait for her to get back if i need it.
Thanks.
Thanks.
