angus67
Welder's penetrate deeper!!
chit!!! Ive got a friends 71, all original, 700 miles
In 93, he was racing it, and it locked up at 90mph. he let it cool down, and it re-started, and got him home. it smoked like crazy, but it ran.
He gave it a ring job and a honing, says he put it back together just as it came apart. the most it would do it sputter, and die.
fast forward 17 years, and its my turn.
full battery, new points, strong spark, chain/valves adjusted. the atu disk, and pionts cam is lined up, compresiion is 95/110, holds compression(no leaky valves) 95% sure the cam is set properly to the crank. the spark plugs are new bpr7's gapped at .025, points are set per the xs1-b's service manual.
I cleaned out the carbs, the float needles looked fine, cleaned the emulsion tubes, jets, 1 turn out on the idle screws.
Gave it a shot of either, and filled the bowls with fresh gas, started kicking
and kicking
and kicking
Got it to spit thru the carbs a few times, I thought i had it when it actually started with the choke on full, was able to idle, even. sounded ok. reached for screwdriver to adj the idle screws, and it died. filled the bowls back up, started kicking
and kicking
and kicking
only getting spitting from the carbs, and an occasional blub,blub from the exhaust.
Then it starts blowing the main fuse, wich is the only fuse. I have the airboxes off, so the batterybox is just kinda hangin, so what I think was shorting, was the power wire(brown/white stripe) to the blinker unit under the batt box. so I zip tie the batbox up so that wont happen again. I converted the glass fuse to a blade. those thing cost quite a bit when your hunting down a short.
It has a very strong magnetic pull from the rotor when I turn the ign on.
Ive been trying to test the regulator and the rectifier, but I think my meter is broken.
I have my meter at 200ohms, my meter zeros out, but, when I touch the black to ground, and the red probe to the appropriate wires, my meter shows "1 ." , does this mean the regulator is bad? same with the regulator. no broken wires, all connections look perfect and clean. I want to ride this piece of history. its as old as me. and Ive never rode a stock 650.
I got my 80 650 in crates, and its close to being done, but just want to feel the difference between a stocker 650, and a hardtailed 680.
help.
and kicking
and kicking
and kicking
and kicking
help.
