This gives a lot of faith in the quality and accuracy of the kit....
Indeed. The point Gary is making is that the "TX" designation was only used for the <I think> '73 and '74 models while the 1976 and on-wards bikes were all labelled "XS650" (with suffix letters that indicated the year and whether the bike was one of the "cruiser" styled models). So, a '75 was an XS650B, the '76 was a "C", etc.
Anyhow - many people have found the those aftermarket generic carb kits contain lots of parts - many of which are either out of spec or simply not applicable to the captioned model. The other thing is that with these old bikes having been built for so many years in such large numbers, there has been a great deal of parts swapping around from one to another. You
might have a 1977 registered bike, and the carbs might
look like 1977 carbs, but some of the parts in them may simply not be correct for that bike. The parts will all fit - because the carbs are all Mikuni BS38s - but they will not function properly together.
The one other issue which I don't think you have mentioned is the float bowl fuel level - as pointed out by Grizld1.
I have simply checked mine statically and that has always worked fine but you can check it while running. You will need a bayonette fitting that can thread into the bottom of each the float bowl (thus, you'll need two) and a short piece of tubing to run up the side of the carb as a "sight glass". That will confirm the float bowl fuel level while the bike is running (it should be just about level with the joint between the bowl and carb body if I recall correctly). There are photos on the Forum of this set-up (I know that
Mailman has done it and posted a photo). Perhaps your float level is set a bit too low and the engine is running lean at higher RPMs - which could account for the "miss".
From the video you posted, it sounds pretty good - until you get that miss at 5,000+RPM. I'm sure you are close - but keep searching because it certainly sounds like something is just a bit off. 2M's suggestion on the air filters is definitely a possibility - these bikes seem to be fairly sensitive to intake irregularities.
Cheers,
Pete
