Installing a Vape all in one charging and ignition system.
Good one, the OEM mechanical tacho could be off too. Well the readings differ. At some points I looked like the reading was pretty much identical, some rpms there was a difference. The 400 is about the max deviation I observed.
Well, if the 400 rpm deviation was seen at the 7500 rpm redline, that is just above 5%. Which definitely could be the deviation/ inaccuracy of the 40 years old mechanical tacho. I doubt Yamaha would have them read less than actual rpm......Mechanical speedos are known to be notoriously "optimistic", so it is very likely that mechanical tachos are the same.
Hey guys, maybe I missed it somewhere but does this system have a rev limiter?
Yes if if you set the 1,2 and 3 dip switches to on and 4 off. this is how it works..- Starts at 5°, advances to 40° at 3000. Keeps that till 8000 and than throttles the engine back so that you can not surpass 8000 revs. - I have a dyno picture somewhere i will try and find it.
I'm running on the stock settings (top one). Can't find anything about a rev limiter here but I assume it's the same as the 8000 max ?
Btw what settings are you running?
They call it throttle back so you can not surpass 8000 revs., I always used the top one with the switches off.
Sorry for the super basic question but I have a 1975 XS650 with electric start has anyone had any issues running the Vape system with an electric starter? I asked Vape if it was compatible and they said no but reading through the thread it sounds like some of you are running the vape system and keeping your electric starter.
The VAPE has proven to be an excellent and reliable system for me. It has no bearing on the XS electric start system and actually provides better charging vs the stock system: so you'll be fine.
Thanks JPdevol that's super helpful wasn't looking forward to having to send it back to the Czech Republic. I'm planning to use the same battery you're using too so good to know you've not had any issues. Thanks to all those who posted before on the thread too, there's a load of great information here.
Just to be clear; you can use any battery with the capacity specs above that fits your battery box. If you go LiFePo4, just make sure the max charge doesn't exceed 14.5VDC. IME there is no need for a special "Lithium" regulator (typically 14 - 14.2V max) with the current crop of Shorai or AntiGravity brands
Thanks JP. The reason I ask was there is a VAPE dealer (not Hoos) that is selling a recalibrated reg/rec for the VAPE system that is used with a Lithium battery. I use a Shorai LFX14A2-BS12. I don`t know what the Max charge rate is for a VAPE but I told Gary Hoos what I was using for a battery and he thought it would be OK. For no more than I ride it probably will.:thumbsup:
VAPE Regulator specs - XS Kits come with 9522 Regulator (for us geeks):geek:
All the above mentioned has to be taken into consideration when you read the below table of average voltage values.
engine
speed
(revs/min)
no regulator
no load
AC output
of stator
regulator 7300
output in volt,
no load
regulator 7300
output in volt,
50W load
regulator 9522
output in volt,
50w load
no battery
regulator 9522
output in volt,
50w load
no battery
with condenser
regulator 9522
output in volt,
50w load
with battery 12v
V_bat = 14.4
with 50W = 11.9V
5006.37.43.22.22.211.8
100010.213.96.45.95.911.8
150015.113.910.89.39.312.0
200019.813.913.611.812.612.4
250025.713.913.810.3*14.413.0
300030.813.913.88.5*14.413.4
350036.913.913.88.2*14.414.1
400040.113.913.87.4*14.414.3
450046.813.913.87.1*14.414.3
500050.313.913.86.4*14.414.3
550055.813.913.86.2*14.414.3
600061.913.913.86.0*14.414.3
For the strange voltage readings marked here with an asterix (*) see explanation here
Hello Bjorn,
My electrical system is the same as yours. : Vape ignition and daytona Velona tachometer.
Is your solution still working ok?
To be sure I understood : You use ingnition coils that have a 5Kohms resistor included, with a BP7ES or BP8ES (without resistor)
Thank you for your help...:)
Luc.
Full disclosure; While talking to Gary Hoos about his cam guides I agreed to do an install of a Vape and a forum write up. Gary gave me a super deal on the set up in exchange for doing a "positive write up". Will attempt to do an impartial, install how to, and comments about how the install goes, and how it works.
http://www.hoosracing.com/home.html
the Vape is several items down in the new XS650/750 engine parts menu.
Since Ywain is on the lift with no charging system at all it seemed like the perfect candidate. This thread will take a while, cuz the bike is far from road ready and it's mid winter in Wisconsin
Package arrived two days from order. Gary is only a couple hundred miles from me.
Well packed
The contents
Includes an instruction booklet, in english except for the wiring diagram.
First up; lots of cleaning to do.
YWAIN had a "never wired up" pamco bolted on, that and the advance assembly are now removed.
Stay tuned.
Oh; feel free to comment, whatever, but I will edit this thread to keep the flow going, combine posts, remove off topic wanders etc.
Got some cleaning done.
A VERY basic wiring diagram
Important concept: A Vape has 2 completely separate circuits one to power the ignition and a "lighting circuit" that handles all other electrical loads.
The ignition is "shut off" via a ground wire. The grounding is done by a relay controlled by the lighting circuit.
I have a 1978 XS 650 would this system work on it. Thanks. Bill
Hi! Im looking to add back a E-start to my bike and am running the Vape system. Im exploring the possibilities to add a strong enough Battery while keeping the weight low.
I appreciate your comment about running the anti-gravity batt with a vape system. If I understand correctly, you have a positive experience with the standard vape reg/rec ?
I have no experience so far with Vape/ AntiGravity on an XS.
But I do have an RD350 with Vape and a small Super-B LiPoFe battery. This setup has worked great for a number of years.
I have also used a Super-B on the XS with the stock charging system, as well as on a Ducati Monster 600 with stock charging system. Also with no problems.
I believe Super-B is made in The Netherlands, so I would recommend you look into them as an alternative.
