1. Dismiss Notice
    Dismiss Notice
1974 TX650 New Owner Help/Tips
Discussion in 'The Garage' started by cmarts, Apr 7, 2018.
  1. cmarts
    cmarts XS650 Enthusiast
    Hi I am a new bike owner and I recently purchased a 1975 yamaha xs650 (TX650B?).
    Heres what I know about the bike.
    It was originally purchased from a farm in Southern Saskatchewan where it had been stored in a barn for a long time. The previous owner lost interest in the bike and let it sit for a while, letting the gas rust the tank more than it already was. When i acquired the bike it was still running and idling but the owner claimed it would stall after getting up in first gear and all that was needed was a carb sync. The previous owner also rebuilt the forks and carbs as well as replaced many parts as listed. It has a little over 7000km in original mileage.
    -Shaved frame
    -New front and rear tires
    -New throttle cables and assembly
    -New tach and speedo cables
    -New brake lines, brake lever and master cylinder
    -New handle bar switches
    -Renthal handle bars
    -New spark plug wires and condensors (only 1 installed for some reason)
    -XS pod filters
    -Custom exhaust
    -New lowering rear shocks
    -Bronze swing arm bushings (not installed)
    -New battery
    So far I have rebuilt the petcocks, lined the fuel tank with por 15, throughly cleaned the carbs, fixed the bendix gear, replaced the oil, and adjusted/lubricated clutch and throttle cables. Stripped the tank of paint.
    My future plans are to powder coat the motor and rims. Replace the bendix gear (clip had already been tightened once and has lost its strength. Gear is chewed up). Paint the tank. Fix the clutch cover where I stripped 2 bolts into the block. Sync and tune the carbs. Take it out for a test drive when it warms up (-22C on April 6th).
    My main issues right now are with the carbs leaking gas from the bottom of the bowl (as shown in picture). Not sure what the issue could be. Carbs are BS38 CV solex non linked with rebuild kit from Mike XS.
    I would appreciate any helpful tips going forward with my project.
  2. MaxPete
    MaxPete Lucille, Betty & Demi - I suggest but THEY decide. XS650.com Supporter Top Contributor
    Ok - welcome to the group!
    Just a small thing - the correct designation is XS650B for the 1975 model. The TX designation was used on (Ithink) the 1974 model.
    Pete
  3. 650Skull
    650Skull Dinosaur Lives Top Contributor
    May need to properly identify the carbs. Early carbs had Solex on the cap and was removed from the top covers in 72.
    Early 70XS1/XS1B....................Note main Venturi floor is raised on early Carbs 70-73 P1000846.JPG user743_pic22692_1441041309.jpg
    In the second pic you can see the early carb Choke/Starter crossover strip is the odd strap joining the carbs. This is only on the XS1/XS1B Solex Cap carbs
    74/75 Carbs wouldn't have had the solex on the carb cap, These caps can be interchanged though so it is not a given.
    Note the floor of the main Venture is not raised and the choke/starter is on one carb only and there is a crossover pipe for the second carb choke/starter
    On the carb kits from Mikes the needles have to be identified and checked against your existing needle........some of the carb kits used to have generic needles and may not match the carb it is intended for..................Another thing, if the carbs are the early 70-73 type and the carb kit was for the later 74/75 then you will run into problems
    On the leaking fuel..................Floats are stuck or the Float needle needs to be replaced or the seat is worn/damaged
    robinc, Mailman and MaxPete like this.
  4. cmarts
    So these have a choke on one side only thats not linked, the venturi floor is not raised, but there is solex on the carb cap.
    They are 74/75 BS38 with early BS38 solex top caps?
    Thanks for the insight. No wonder i couldn't figure out what year they were.
    As far as the leak is going, im 99% sure the float is just getting stuck (see last photo). When the float needle is fully extended is rests on the floats at an angle, jamming it in place and stopping the floats from raising. How do i stop this. Is it because they are the wrong type for the carb because they are brand new.
  5. 650Skull
    74/75 carbs.
    That does look steep. Has the float height been set?
  6. cmarts
    yes float height is set at 25mm
  7. fredintoon
    Hi cmarts and welcome,
    just a thought on those dangling floats, can they fall that far with the carb bowls in place or will they bottom out before they reach that angle?
    TwoManyXS1Bs likes this.
  8. cmarts
    I don't think they can. I tried to replicate the floats sticking open with the bowls back on.
    gggGary likes this.
  9. cmarts
    Update:
    All good now with the leak. The float was stuck open.
    Fired up the bike. All good. Set mixture screw -1 full turn.
    Began to set idle on left side by pulling spark plug wire on right side.
    Set idle on left side.
    Started bike again and now I cannot get it to fire on the right side unless I give it gas up to 2500-3000 rpm. Just blows gas out the exhaust.
    Right side has good spark. Good fuel to carb.
  10. cmarts
    Got the bike running good....not perfect. Heres a drive by video.
    Current Issues / Finishing touches:
    1. Front sprocket oil leak. Tightened sprocket nut, didnt help. Replacing seal.
    2. Right side carb idles best with air/fuel idle screw fully seated. I think that means theres too much air getting in. Butterfly shaft seal on order. Will also check butterfly valve if it seals correctly.
    3. Right side exhaust header clamp does not tighten down fully to engine. 1/2" gap. Exhaust leaking through header. Popping on decel. Gaskets on order.
    4. Stripped exhaust valve cover stud on right side. :banghead: Will rethread and helicoil. (Any other options)
    5. Rebuilding gauge cluster with custom piece of laser cut aluminum, using original speedo/tach/ignition. Have design file if anyone would like.
    Any recommendations would be appreciated.
    Thanks
  11. 5twins
    18,781
    9,555
    688
    Your mix screw is a true mixture screw, regulating fuel (fuel/air mix actually) into the idle circuit. Turning it in (closing it) will lean the idle circuit. So, if you have to close it, it appears you're too rich on that right carb. Your float setting could still be off, or the float needle leaking some. That would over-fill the bowl and that would cause rich running. Best way to verify fuel levels (float settings) is to check with a clear tube afterwards. Fuel level should be no higher than the bowl - carb body seam .....
    [​IMG]
  12. cmarts
    Update:
    Bike is running and driving.
    Timing good, valves good, compression ok (110 left, 105 right, valves are very carboned up).
    I can’t for the life of me figure out the right cylinder carb. 130 mains 42.5 pilot, pod filters, straight piped, 74/75 bs38’s. Idle screw at 1/4 turn from seat. Popping on deceleration. I have been able to get rid of the popping by turning the idle mixture screw out (enriching) 1/8 turn, but after riding a while the popping returns worse than before. Turning the idle screw out anymore and the bike runs like crap at idle. I’m not sure what else I can look at, I have read the carb guide and checked everything. Floats are set correctly, tested for air leaks. Left cylinder runs like a dream.
    Time for new carbs?
  13. weekendrider
    weekendrider Iron Horse cowboy Top Contributor
    5,686
    1,175
    213
    S.W. MO
    May be the pilot/slow speed circuit needs cleaned? Not just the jet but the passages?
Share This Page
