acecafe1000
- Messages
- 12
- Reaction score
- 0
- Points
- 1
Well, finaly broke down and bought a compression tester...found out why my right cylinder wasn't firing - zero, absolutely zero, compression. 120 on the left.
Done the basics, cam chain, valve clearance...with the valve access covers off, spark plug out, cycling the engine...from the minimum amount of surface area i can see on the pistion, not seeing any nasty holes. Valves are working as far as i can tell...and can see them peek thru the sparky hole. Tells me they are at least not hung up, not grossly bent. My qeustion is...shouldn't i be seeing at least some compression if my valves aren't fully seating? Shouldn't i see at least some compression if the rings are shot?
Before i checked the compression, when i discovered the one cylinder wasn't fireing, this is what i witnessed with the bike idleing off the left side only:
- put hand on dead cylinder pipe, sucks your hand to the pipe,
- rap the throttle, popping, air blow back thru the carbs...in sync with the piston
- pulled the plug and it shot out of the engine once i got it off the last thread - serious air push thru the spark plug
- absolutly now rattling, clanking, etc. while running.
Going to play with it some more tonight to see if i can track down where all my compression is sneaking out...before i learn how to tear into her.
Have i done absolutely everything i can do before opening her up?
