Yes, the diagrams JP has posted pertain to the BS34's. A BS38 set at 24mm would be about at the bottom edge of the main body .....
But, the spec for the '76-'77 carbs is 25mm, so that would put the level slightly lower than pictured above. Here's one I found set at 26mm, so you could split the difference .....
As far as the floats go, I found they are nothing special, just the common and readily available Mikuni VM24-171. These are available from many places for around $15 or less .....
I have purchased some and compared them to originals and they are an exact match.
