VVLynden
It's summer time and I'm dinkin' around again with the bike. Had a quick question, is the sump oil filter cover the same across all years? Before I bought an actual lift for my bike I had used a scissor jack and.. well.. Used the bolt where you drain the oil from as my jacking point. Definitely a live and learn sort of thing. Anyhow, when the engine runs I get some slight leakage, whereas before this jacking snafu I had no problem. Thinking the best option would be to replace that panel.
Other than that, I've got drum brake pads on the way, a new rear brake light switch, and a throttle cable bracket. I need to shorten my throttle cable and looked up some vids, looks like I get to try my hand at some soldering. After that, need new pads on the front disc brake, master cylinder, then it's time to give it a test run! Just waitin on some dough for the master cylinder.
