I have read through a lot of the posts on here and am having a hard time find a clear response on Air Filters:
I currently have installed the MikesXS OEM Air Filter: Part # 15-0653. The foam has chunked off.
Do you recommend completely replacing with the same OEM? Or as I have seen everywhere replace the foam itself over the existing cage and use a UNI foam filter sheet.
If i use the UNI filter sheet do i need to do anything with the carbs or will the air flow be similar? (Im seeing the UNI's have to get soaked with oil too)
Thanks for the help ahead of time.
