Scrambled
Motorcycle Man
I had one of those back in '74. Love the old motocross bikes .Not an XS but... I restored a 1974 Honda CR125M Elsinore this year..
Unless you can find some clean used ones I think that Mike's is your only option. I never thought the stock ones were that good either , in fact I am in the process of looking for the snail cam type that were used back in the '60s on British trials bikes and are still used on motocross bikes today , if I can't find any that fit an XS I will have to design and build my own. I have a few simple ideas that should work .Scrams... I dont know yet, cant remember if there was or not, I seem to recall it bolted directly on... I will most definately know when I get that rear wheel done and both back from the shop... new rim strips, tubes, stems, tires, truing, and balancing... then I mount and we will see about that brake...
which reminds me...
anyone try those rear wheel tensioners from mikes xs?
mine are real bad and i would rather get new ones instead of painting them...
however i seem to recall someone on here saying they weren't any good from there.
Trying to get through cleaning up my rear wheel... holy crap that drum hub is a beast! this has taken all my time until....
tonight i got my hands on a ultrasonic cleaner!
wow!
here is a before and after of my petcock... no polish just cleaning and rubbing down ( full disassemble and rebuild w/ mikes xs kit...) (the kits gasket for the rear bowl may be garbage, its less than a paper thin piece of rubber and the original is quite substantial)
[/IMG]
[/IMG]
[/IMG]
[/IMG]
Also,
I received my new, new, centerstand from mikes.
the first one was such bad quality I couldnt use it. so after a while it is all sorted, ( mikes was great and even checked it before sending the new one, refunded all shipping and was very communicative)
the only issue was it was slightly narrow so, trusty piece of threaded rod, most likely my most useful non tool, tool.
[/IMG]
Subscribed. Looking forward to it.So lets see how this ultrakaboom super cleaner handles my float bowls with a 1/4 inch of 30 year old gas sludge in the bottoms... More to come, this weekend might be a carb teardown segment. Havnt seen a really good documented play by play on here for older bs38s
