Rogerallday
XS650 New Member
- Messages
- 4
- Reaction score
- 0
- Points
- 1
Hello All.....
For sale is my 1980 Yamaha XS650 custom built bobber by Jamie Elswick from Elswick Cycles. Runs Great & Strong, Being currently used as my daily driver. Engine has about 5k Miles.
Pamco Pete Ignition also installed allowing for a simple electric start. Kick start also works.
The bike has a complete custom single downtube, continuous backbone dropseat frame. It has a 35 degree rake, 4″ stretch in the rear, 4.5″ ride height with the 16″ rear and 19″ front, neck is 2″ lower than stock and it has a +4″ stretch in the backbone. Backbone and down tube are .250″ wall 1 1/2″ d.o.m, bottom rails and seat tubes are .156″ 1″ d.o.m. so the frame is indestructible. Frame also has a stash tube at the bottom of the down tube. Frame alone would sell for $1,250. It has a high mounted wassel tank, shaved xs fork tubes with mikes xs pro dampers and has a stem conversion on Betor triple trees to make them work with the stock style neck. Custom kickout exhaust.
These parts were ordered from MikesXS and installed.
Gran turismo grips-$12.50
EK 530 srx x ring chain 150 link-$142.00 f
Auto advance unit-$59.00 Part #14-0652
Advance rod-$29.00 Part #14-0650
Coil cap and seal set-$3.00 Part #17-6804
Spark plug high tension wires-$4.50 per set Part #23-2902
Alternator brush set-$15.00 Part #24-2651
Solid state rectifier/regulator-$99.00 Part #24-2087
Starter motor brush set-$10.00 Part #24-2064
Starter Relay-$15.00 Part #24-6526
Battery positive cable-$7.00 Part #24-3504
Battery negative cable-$4.00 Part #24-3505
Cable-battery relay to starter motor-$8.00 Part #24-3506
Carb parts
Carb rebuild kit-$12.00x2 $24.00 Part #48-1408
Heiden dyno tune needle and jet kit-$44.00 Part #48-0667
54mm xs performance pod filter-$16.00x2 $32.00 Part #15-0035
New Unlimited Parts AGM battery was recently purchased aswell from Del Amo Motorsports and I still have the receipt.
Thanks for looking guys.
Carb parts
