snyder650
I have found the way I described is easy for me on the bikes I work on. May not be the only way, just the way I do it.
Now on the LED turn signals you will need to get a flasher that can flash LED's. I like the one from www.superbrightleds.com The LF1-S-Flat $8.95. When you get it you remover the wires from the plastic they are in. Then you can plug the Flat blades into the stock flasher socket. The socket wire colors you use are the brown and brown/white. The flasher can have either a red or grey wire and a black wire. The red or grey wire plugs in where the brown wire is, the black to the brown/white wire.
Ok. I'll check out that flasher. If I have problems or questions, and can't find it on the forum, I'll start another thread.
Thanks for your help,
Andy
