scott s
XS650 Guru
I have an engine that came in a parts bike. The bike was a '74. The color, VIN, mufflers and other clues led to to belive that it was a '74.
The engine, however, almost certainly isn't. I've used the "How to ID your model" charts and that just led to more confusion.
The number on the engine appears to be 3650-120924. It's hard to read behind the engine mount, so I'm guessing that the "3" is and "S". S350-120924 would put this as a '72 engine.
HOWEVER, my manual says that the early engines hold either 3.2 or 2.6 litres. The engine case is clearly marked "oil capacity 2500cc". which would put it as a bit later.
If it IS an XS 2 or TX 650 engine, the manual states MUCH wider valve clearances. .006 and .012 vs. .002 and .004.
What do I have and where would you adjust the valves?
