'75 Cafe Build
Damned parts fiches anyways.
This Yamaha 447-24510-02-00 FUEL COCK ASY 2 is used on these models and components:
1970 XS1 FUEL TANK
1971 XS1B FUEL TANK
1972 XS2 FUEL TANK
1973 TX500 FUEL TANK 1
1973 TX650 FUEL TANK
1973 TX750 FUEL TANK
1974 TX500A FUEL TANK 1
1974 TX650A FUEL TANK TX650A - XS650B
1974 TX750A FUEL TANK
1975 XS500B FUEL TANK 1
1975 XS500B FUEL TANK 2 XS500B
1975 XS650B FUEL TANK TX650A - XS650B
1976 XS500C FUEL TANK
1976 XS650C FUEL TANK XS650C
1977 XS500D FUEL TANK
1977 XS650D FUEL TANK XS650D
I don't fully trust those parts numbers that give you the models they are supposed to cross over with.
The build has been coming slowly in the new year. I've mainly been cleaning up the frame. Cut the rear fender bracketry off, fabbed up tabs for the turn signals. I have an LED tail/brake on the way, inspired by this CB750 build. Luckily it is free, since my dad works in the trucking industry. I also bought a CB750 left hand (turn/horn) switch, and will drill the handlebars to run the wiring inside. I have to admit that it is quite uncluttered for an OEM design, and I couldn't find anything I really liked.
I'm also considering removing the plastic, forward section of rear fender, and mounting the regulator on a bracket at the front of the frame a la this XS by Thrive.
Got the tail light fitted, though I'm going to redo it by bolting directly to the seat. I also broke down and bought a Sparx capacitor in lieu of soldering up my own. Prior to installing, I took my capacitance tester to it... and found that it's only a 4500 uF cap. That's appalling, but I'm going run it anyway, given I'll have full LEDs less the headlight.
I've run wires, with the intent to go in-frame to hide them. I'm also planning to bolt the rec/reg to the underside of the seat to hide it a little better.
Well, I got her mostly buttoned up, and have ridden her around the block a couple times as I worked out some kinks. The carbs definitely need to be tuned, and the electrics box redone. I picked up a smaller ignition switch, so I can further reduce the visual mass around the seat.
I sold the seat, so I'll be purchasing one from Counterbalance soon. And I'm going to swap out the forks for 35mm units. The plan is to upgrade to a fazer blue dot or Brembo, and I already have an 11mm master ready to bolt on.
Once I get it road worthy, the real fun begins as I get to pull everything back apart to clean it all up up and powdercoat some things.
Pulled the trigger on some blue dot rotors + calipers and 11mm master (I'll only be using one side). I used a template from this thread, which I played around with a bit converting into a CAD file. I also designed a gauge panel for the OEM gauges, with holes for headlight and kill switches. This will be modified when I get new gauges.
I'm going to make my own brackets for mid- or rear sets, likely using a DIY kit from Old School Speed or something similar. I don't have a provision for passenger pegs, which I'd like to have... I don't think I've seen any other bikes without the hoop, is that normal? I'm planning to design a single bracket for both, which will use the OEM 2-point mounts, extending rearward about 150 mm for the passenger. That's still in the concept stage, however. For now, though, off to the water jet...
Here's also a preliminary drawing of the spacer. I'll mock up the wheel when I get the rotors, then finalize thickness.
