79 Special II RestoCustom "Doomy"
Here in the shop at work today I'm heading into the needed custom side covers. Fun that the 81 side covers I found are plastic so quickly sawing off a lot of the extra will go fast. From there I'll shape these into small custom shaped side covers which will attach to the battery box threaded holes which were for the airbox halves via posts
:thumbsup:
Test cut noise drew enough attention from coworkers that I'll have to be more stealthy :lmao:
to be continued..
-R
Roughed out oversize quick & dirty at lunch while chewing lasagna lol. No safety Nazis present in the shop. Now they go home for more accurate shape marking.
-R
Edit Update, next morning ;)
Yup slipping in more for those of you watching lol.. Yesterday at the vertical band saw here in the shop someone actually reported my lack of a holding fixture and that "safety concern" was brought up. See, working in a machine shop these days is not at all as it used to be. Plenty of puss rules now as the "dying art" of hands on manufacturing is truly in jeopardy.
Anyway, the "Special" shape side covers are rather bulky and triangular compared to a "Standard" side cover so the goal here is with shaping, smalling, and visual illusion to create a more Standard like side cover. Last nights progress check confirmed there is plenty of extra plastic to whittle away. Shaping plastic body parts has been fun in my distant past so here goes more on the XS hang in there,
I'll get there ;)
I've not seen an OEM fender flake when cutting...assuming it's fairly trust free, for what that's worth...aftermarket is a different story. But, you may want to put some painters tape on the fender along the line where you're going to cut (cut down the middle of the tape)...that should help.
At the end of the work week I'm walking out the door with parts to play with. The fender cut nicely (loudly) and I squared it up on the disc grinder and de burred it for fit checking for lengths. Hoping to put some descent radius's on the ends but not today.. And the side covers are much slimmer now and will be even smaller in the end.. starting to understand the custom builders habits..
:thumbsup:-RT
Been about a week now not actually doing any mechanical work on the XS. I have however been gathering little bits such as the brake booster check valve (3 auto parts stores to locate1?) Jeez, a descent uncracked clutch worm, side cover badges. BTW , I need Chrome Silver Special tank badges still :whistle:
But here is todays question ? After jumpering the black/blue wire to the black/yellow wire in the light RLU box, cant I just cut the whole bulky plug off the harness and cap the other wires instead of leaving it to stuff in there ?
I guess you could cut the plug off the RLU connection but it easily tucks down behind the battery box out of sight. There's lots of room there for it. Mine's even bulkier because I put the jumper wire in a matching plug, but it still fits fine .....
