Great advice thanks.
And I tell guys to just move the lever very slowly. It's not a switch.
Be slow and reduce possible damage
A tip on rebuilding these, or any petcock for that matter - besides polishing the face on the back side of the lever, take a small sharp pocket knife and remove any burrs or sharp edges around the tops of the oval slots. Those can tear up the rubber disc when you rotate the handle. I use some silicone rubber lube on the face of the rubber disc, and on the back face of the lever, and the rebuilt unit usually comes out working like new again.
Absolutely ! Yes, the existing wires are mis matched and damaged caps.Something else I would consider doing during your "wake up" drill is changing those original looking spark plug caps. Throw some NGK 5K ohm caps on there
79F mfg date is 5/78 Owners manual printed 4/78I have the same 79f, my frame says 78 though. Does your frame say 78?
