johnlaw
I have been working on an 81 650, on start up the left pipe blows grey smoke that clears up pretty quick. I only got to take one trip for about 3 miles. It ran great for a moment then I could tell it was only running on the right side. A couple times at mid throttle the left side came back to life and then nothing. When I pulled the plugs the right one was black, and the left one was wet, but looked almost new. Both sides are getting spark, and both sides were at 150 psi when I did a compression check. I rebuilt and re jetted the carbs for pipes and pods. I checked the voltage after installing a new battery. 12v at idle 14v while reved up.
After ruling out spark, compression, and the charging system, I tore the left carb back apart and cleaned it again. After re installing and topping of with some premium fuel, I fired her back up. More smoke from the left pipe, and a lot of spitting and sputtering, and backfiring, it seemed to clear up. I only got to run it up and down the driveway a few times, and the warden said it was time for supper.
I hope it is cleared up otherwise I don't know what else to check.
