What does it sound like if you kick it over with the plugs removed?
Well holding the clutch in makes the kick start slip so it doesn't turn over the motor unless ur asking bc compression ?
Kick it over without the clutch pulled in to see if it sounds different without pushing against compression.
Definitely will do! I'll take a longer video of every point once I get back home ! I appreciate everyone trying to help really I do I don't wanna hurt the fresh rebuild of the top end
Tried but sound the same from all positions
Just curious..
Is this issue on the award winning bike you built three years ago?
It looks like you have done some other updates since that article.
Not sure I hear anything specific. Is your timing correct? Have you taken your valve covers off? Making sure they are functioning and you don't have a valve sticking?
Working on that tomorrow but it sounds like the bottom end somewhere an nothing down there was changed
I can’t hear anything unusual. Maybe someone else with better ears?
I hear a definite clunk at the bottom of the kick stroke in the first vid and it's still there (but quieter) in the last one.
I'm more amazed at anyone kicking over one of these in their socks.
OP, was that last vid with the plugs out?
Could it be that the clutch is adjusted to tight (havnt gotten to looking at it yet)but could that cause that soundIs your clutch rubbing on the inside of the primary?
Yes, If you over adjust the clutch it could push it out towards the primary cover.Could it be that the clutch is adjusted to tight (havnt gotten to looking at it yet)but could that cause that sound
Clutch was not a problem I un adjusted it all the way out to see if it changed the sound an still the same sadlyYes, If you over adjust the clutch it could push it out towards the primary cover.
