Cal Schilling
r u using the choke? your idle should jump way up. that idle is way too low. pull the bowls off and clean the enrichener circuit.
when u uncovered your idle mix screws, did you remove them and really clean it all out good?
When you replaced the throttle shaft seals, are your plates centered in the bores?
No choke
Removed and cleaned them really well along with all the passage ways
plates are centered
The recommended idle speed is only 1200 RPMs why should it shoot way up if there is no choke?
