5th Gear Overdrive:
The 5th gear overdrive has been mentioned in a few of the builds here on the forum and it came highly recommended to me from a talented builder so i decided to go ahead and do it. mikes xs has the part listed here:
http://www.mikesxs.net/products-22.html#products
heres a bit of information about it:
this goes off topic but begins well:
http://www.xs650.com/forum/showthread.php?t=411
a good build with lots of photos (takes for every to load though):
http://www.xs650.com/forum/showpost.php?p=140580&postcount=3
i couldnt find much on which actual install until i came across this build which helped a lot:
http://xs650temp.proboards.com/index.cgi?board=project&action=display&thread=4858&page=4
the transmission how it would be in the case; my finger pointing to the gear that needs to be swapped:
theres a spring clip that keeps the gear in place, next a washer, then the gear can slip off no problem:
5th gear overdrive left, stock gear right:
all back together, my finger pointing to the 5th gear in place:
easy breezy!
