fitting a HD narrow glide fender for xs650:
ill be running a front fender on CALLLING ALL DESTROYERS.
the stock fender is bulky and though I'm confident i could chop it up into something rad it will still be too wide for the thing 21" tire. therefore I've decided to go with a HD narrow glide fender for the front and for the back. this calls for some modifications:
1) i determined how much space i wanted between the fender and tire.
i installed the tire and then put spacers on it, finally setting the fender on the spacers.
notice how there is a gap on both sides between the fender mounts and the forks:
2) the stock mount holes are lower then i want based on the spacing I've determined so ill have to move things around:
3) this scored line represents the centerline of the new mounting holes ill be drilling:
4) width of holes was determined and punched
5) pilot holes:
6) a step bit was used to get the proper size for the hole:
7) i found some spacers are the proper length over at the local hardware store that fit perfectly.i used socket head cap screws to install the fender but will probably swap them for button heads:
