These appear to be the internals of an RD350 1974, taken from another forum. Should be the same as mine ('75).
So, it would seem important to have the dimensions from your nice dial caliper of the two largest (outside) diameter parts of the damper tube, which I put an "X" on in the picture, which I imagine have the same diameter.damping for XS2
View attachment 114009 View attachment 114007 View attachment 114008 View attachment 114009 View attachment 114010 View attachment 114011
not sure what dimensions you require
......and as I see it, the overall length of the damping rod is 21mm, yes?damping for XS2
Now we are really getting somewhere !some more dimensions:
View attachment 114023 View attachment 114024 View attachment 114025
The piston (Item 7) is the same for both 73 TX650 and 73 RD350.
Actually I haven't used these callipers since 1984 I think.
The caps for the RD, TX and XS2 all have the same last seven numbers [ xxx-23111-60 ]. Can we assume that all three of these models use the same caps?and use TX650 caps
damping rod mods are popular at the RD sites. There are threads detailing drilling more holes, as well as welding some shut, as well as adding emulators (adjustable valves).One key difference I see in the pistons is that one of them has 8 holes and the other has 12 holes.
That could have a significant effect on the damping provided by the forks - depending on the other characteristics of the oil passages in the forks.
Pete.
Although there might be some subtle diffferences, there are a number of fork caps being sold on EBay which are noted as (basically) fitting a number of models, although the RD350 is not one of them. This suggests that I would be up against buying new or used ones.
