wildboar58
hey i have some 3/16 disk magnate s bout .150 thick can i put 2 on the pick up or i one enough?
Rotors rotate, stators are stationary.i mean the one on the stator ,that picks up the slip rings on my 81 xs
Back to my first answer then, it doesn't have a magnet. Putting one there would block the rotors magnet.it is stationary ,its black oval it sends signal to t c i .thats what i mean.
so you can dig them out.if you glue them it won't hurt anything .
For starters, follow the ignition troubleshooting tree in the Yamaha manual.ok thanks for straitening me out I guess I misunderstood on where magnets would go. the bike started up fine after rebuild ,the problem I'm having is it wouldn't start up later on.i tested the coil with multi meter it is in spec.i tested the rotor and its ok .the battery in good its glasmat and new ,when I turn key the neutral light comes on and horn works but no spark.
Highly recommend it!yea it looks like my tci box is bad. you cant buy them anymore can you? i,m looking at the gonzo suzuki gn250 i think i can wire it .
