Air Filters
Nope, most are using the UNI foam type. But if your 34s are the aftermarket VM normal slide type carbs (not vacuum or CV type), it doesn't matter what you use. K&Ns would be fine. Real K&Ns that is. Buy junk knock-offs and that's what you get - junk.
The carbs are the VM34mm, I actually just ordered a bunch of bits and filters from 650direct (Canadian mikes XS) and the parts are on their way.
Cheers
