nobackhair
Have plan to do Minton Mod for drilling of dampers rods in F.forks. My Clymer manual isn't much help in my opinion as to start to finish of dissassembly. So I did find a video on Youtube that was helpful. I've had them apart in the past but I didn't want to do any uneccessary work. Anyway I'm trying to get that allen nut out of lowest part of fork. Used a hammer drill and it won't give. I tapped it good w/ a hammer and allen shaft that fit to loosen what I'm sure was freezing it 1st but it wouldn't budge. I'm suprized I didn't snap the head off when I tried it manually w/ a rachet. Weary about using torch. Anyone know of a liquid that might dissolve any material that's causing it to freeze? It seems like a safe area to use the torch. Even if I get that bolt off will the damper come out? I forgot to mention these are the 35mm from a 78 w/ the reccessed nut at top. I was assuming the drilling of the damper was benificial as an upgrade to a more responsive front fork. I have new Progressive brand springs to add but, while I have them apart somewhat. It seemed like this was a good step. I'm doing all this because I got new Ikon 7610's for rear. My wt. 150, bike 420. Rear springs were matched w/ damper based on those weights. Mike from 650 central said not to do the drilling anymore. He mentioned he needs to do a lot of updating to his site.
