vincejames
Wanted to pull the group on this. I think 5twins might be getting annoyed at my constant inbox messages; even though he has helped immensely in getting one of my three XSs' back on the road! I'm thinking he will still probably chime in when he sees this...
1978 XS650, BS38s. Recently, installed a PAMCO, running a shorter 2 to 1 exhaust w/ a baffle, UNIs, PMA from Hughs. My Main jet is at 145, Pilot at 40, needle clip setting on the third slot, mixture screw 1/2 turn out (anything more makes the bike run poor w/ no idle).
The bike idles fine with the current set up. The issue I'm having is there are flat spots out of first gear and the beginning of second between 2000 - 4000 RPMs range. Once I get above 4000, I get a nice surge of power. The rest of the gears are fine and I'm actually pretty content with the power from 60MPH to 80MPH - I'm thinking my larger main helps here...
I've experimented with going down on my pilot jet to a 30 and my main to a 140 while adjusting the mixture screw. I do not have any other size jets, and will have to order if I'm going to try others. The bike ran poorly with a 140 main and a 30 pilot and still poorly with a 145 main and a 30 pilot. I've had some poor experience with moving the needle clip (not to mention I had a semi-bad air leak), but have not ran the bike with a the needle clip moved w/ my new PAMCO. I'm thinking about moving the needle clip to the 4th position to richen my mid-range (see attached)
Please don't forward me to the carb guide. I've read it and others and am still learning how to properly tune these bikes - I'm more looking for an opinion from the group to see if how they fixed their flat spots. My other two XSs don't have any issues and run fine. It's just this one that has more mods than the others that I'm currently having issues with.
