vincejames
When I had the BS38's on my bike years ago there was a flat spot that no jetting would cure. The issue was the jet needles. I tried a few different needles that I had from other bikes but none of them were right either.
With the CVK34 carbs I was having similar issues until I replaced the dual-taper needles with straight taper needles from an "offroad" carb. The straight taper needles are available in all different tapers, diameters and lengths so I was able to dial it in perfectly.
I'm not sure if there are any straight taper needles available to fit the BS38 carbs but it's worth checking into. Grizld1 was right when he said you are going to have to open your wallet to do it right. I spent hundreds of dollars on jets and needles to get a $50 set of carbs working well.
Sounds good. I've experimented with adjusting the needle clip setting, but nothing seemed right. I've not gone done the road in replacing the needle itself. I have a bunch of jets coming in this week. I'm going to play around and see if I can get the right size pilot jet to do the job.
If not, maybe moving to a different needle might be the solution - or fuel injection . As I said, the bike runs fine and idles perfectly, there are just nasty flat parts out of first, second and third, but once RPMs get up over 4500, the bike pulls nicely.
I'll keep the group posted.
Thanks
