1. Dismiss Notice
    Dismiss Notice
Alternator/Left Crankcase Cover Bolts
Discussion in 'The Garage' started by itsmattyc, May 26, 2020.
  1. itsmattyc
    itsmattyc Chase The Sunset
    Hi all,
    I purchased my XS650 without any bolts for the Alternator/Left Crankcase Cover and haven't been able to find them on the threads. Does anybody know the size/dimensions of the 6 bolts or if there is a kit online where I could buy them?
    Thanks!
  2. gggGary
    Conveniently Yamaha reveals the bolt size in the description!
    so 4) 6mm x 25mm
    and 2) 6mm x 40mm
    About every bolt seller in the land will have these allen heads!
    If you choose stainless a bit of anti-seize is a good idea, stainless tends to corrode aluminum. Tho after years of using stainless I haven't had an issue removing a bolt...
    Also a good idea to flush out holes with a bit of spray cleaner.
    If the bolts start to bind, repeat the spray cleaner and perhaps run a bottoming tap in and out, go easy!.
  3. gggGary
    Greyandridin and itsmattyc like this.
  4. itsmattyc
    Thank you so much! For anyone looking for the other screws (for the Yamaha cover) you can find them on MikesXS part 24-1197 :)
    Safe Travels
    Greyandridin likes this.
  5. Greyandridin
    Greyandridin Got nothing to do and all day to do it XS650.com Supporter Top Contributor
    Thanks gggGary ! I've used Partzilla OEM parts #'s to go searching on the internet for parts but didn't know how to figure out bolt sizes using the parts numbers
    Time to add another thread to the hundreds of XS650 book marks I have already
    gggGary likes this.
  6. 5twins
    19,410
    10,743
    813
    I like to use slightly longer screws for the round cover. The 10mm long screws Yamaha used are too short and don't reach all the way through the threaded tabs they go into. They don't utilize all the threads available to them .....
    [​IMG]
    Greyandridin and gggGary like this.
Share This Page
