tbrenan
the attached shows a boxed arm made exclusivley for the XS650 it may be consider pricey but it is affordable to me considering what it brings in handling
The V-H Racing Swing Arm includes Front Needle Bearings , Sleeve, Dust Caps, Rear Axle Shaft Castle Nut, & Adjusters … Clean & Lube ALL before assembly, & AFTER you have painted or powder coated the S/A. Simply unbolt your Original Swing Arm & Slide the V-H Unit into position, re-using your Cleaned & Re-Lubed Pivot Bolt, Washers & Nut. The 17mm Rear Axle Provided is not the same 20mm diameter as your stock Axle, & you will need to fabricate spacers to fit YOUR particular Wheel / Hub Application. The Stock Rear XS wheel bearings are 20mm & would need to be converted to a 17mm bearing (available through almost any NAPA or Bearing Store - VERY easy swap). V-H Racing can provide “Raw” 17mm Aluminum Spacer Stock, that can be easily cut or turned to fit YOUR Wheel. The Right Front Arm has a provision that can be used As-Is, or EASILY Adapted to fit “most” Brake Stay Arms. The 3-Position LOWER SHOCK Mounts will accommodate many, but not all Shocks Absorbers. The Width Measurement is a compromise for those wishing to use the Stock Upper Shock Mounts, or Re-position the upper mounts further Rearward for a more “Upright” Shock position.
Currently Pre-Sold Orders take approx 3 - 4 weeks to complete ... USD $319.95 in media blast / primer finish, or $359.95 in Powdercoated (almost any color) finish. Insured Shipping ANYWHERE in the Cont US is 20.00. / Canada is 40.00.
You can pay with Check, Money Order or PayPal (although PP requires an "extra" 3% to cover their fees).
Overall length = 22"; Rear inner width = 8.5"; Rear to front Crossbrace = 16.5". Center of Front Pivot to Center of Axle Slot Adjustment = 19.5". They WILL accept a WIDE 19" Goodyear Flattrack Racing Tire on a WIDE rim ... (approx 7" wide).
Photos below.
Call anytime ... 303-810-3827 ...Thank You !!
Go to Vintage Flat Track web page items for sale look at last post in third column ---first bikes. then street, then third column
Photos below.
