I can see that the lower banjo bolt is a 45 degree angle so you can get to nipple but what is the required angle to have top and bottom banjo bolts aligned at? Some of the custom brake line companies allow you to get them at 45 90 180 degrees. Do I need it at 90 degrees or will it twist a little?
I have universal bars on. (low wide) and want a one piece brake line. Has anybody ordered one and what angle (twist) did you get for the alignment of the two bbanjo bolts in relation to each other. Thanks. First build and steep learning curve here.
