Twitchknaf
working on a tc bros hard tail setup the po had swapped to a tx500 wheel previously
Just wanted some input on the way I have this mocked up and measured the chain looks good to me but I'm blind as a bat with one leg shorter then the other
9mm spaced out on the sprocket
Drive side is 3 1/2 inches from inside axleplate to hub
Brake side is 3 3/8 from inside axle plate to hub
