fullercameron
Hugh
Thanks for the info on this. I initially thought that what I was seeing was aluminum, but after some prodding it definitely seemed possible that it was lead. Doesn't make much sense to drill a hole in steel and fill it with aluminum to add weight.
As for when it happened, I rode the bike all day - to work, etc. and took it out that night for a trip to the bank. On the evening ride it sounded like there was something rubbing but all I could tell was that it sounded like it was on the RS of the bike. I thought I just needed to do a valve adjustment and I checked the oil when I got back and figured I'd do some maintenance over the weekend.
Somehow I guess I got tremendously lucky because the plug somehow fell out the rest of the way when I stopped the bike. I discovered the whole thing when I went to kick it over the next day to ride to work and the kicker stopped about half way down - with a definite metallic clunk like I was hitting something bad inside.
I am thinking that I may use this crank and the cam from a spare engine to do a rephase sometime in the future and was curious if this plug can be replaced or if the outer flywheel would just need to be replaced?
