All the stock coils I've seen have a brown and an orange wire. Brown is power from the harness, orange gets a wire from one of the points sets. Most of the wiring diagrams and my '78 have 2 R/Ws for power coming out of the harness, a gray and an orange running from the points sets to the coils (orange from bottom points set to left coil, gray from upper points set to right coil). The points end of each wire has a double female bullet so one of the condensers can be plugged into it along with one of the cloth covered wires that come from the points.
If you have 2 browns coming out of your harness and going to the browns on the coils, those are your POS or power feed wires. Connect one to your new coil and the other to the red Pamco wire. Take one of the wires that goes to an orange on your original coils and connect it to the other terminal on your new coil. Find the other end of that wire and connect the Pamco green to it. You won't use the other wire currently running to the orange on your other stock coil. Points will be removed. Condensers will be disconnected and not used anymore either. You can remove them from the bike or leave them in place as I did, the choice is yours.
