Miltonbradly
XS650 New Member
Hey all,
New member here but I've been around xs/chopper forums in the past... I'm working on a scrambler build and looking to be rid of the battery and unnecessary electrics.... (Starter, solenoid, signals etc). For now I'm working towards a pure off-road machine.
Has anyone played around with building a permanent magnet rotor to fit in the stock stator? I have a few basket cases worth of spare parts, one of them has a rotor that has been separated from the hub that the rotor is presses on to. I figure it wouldn't be too hard to fabricate a new rotor out of aluminum that could have neodymium magnets imbedded around the perimeter and be pressed onto the stock hub...
If I recall correctly the stock rotor has eight magnetic poles alternating north/south. A rotor with eight strong magnets might be capable of at least producing enough power for ignition coils and a headlight? I presume stronger magnets would produce more current? I have read that the stock rotor sucks a large amount of current just to produce a magnetic field. Anyone ever power one up outside the stator to see how strong the magnetic field is?
An alternate thought was of perhaps imbedding neodymium magnets in the "fingers" of a stock rotor to give it a static magnetic field that could self energize the alternator without a battery (if it could produce enough power to drive the ignition as well).
I know there are PMA kits available already... Just looking for a different way to solve the same problem.
MB
MB
