what size spacer are needed?
what side of the wheel do you space?
And do you space between the wheel and the inside of the axel plate, or the nuts and the outside of the axel plate?
Using the stock axle adjusters, you need right at 1/8" on both sides of the axle and inside and outside of the frame. Basically, your 1/2" short and your girl isn't happy.
Ill post pictures of mine once finished, but I didn't like using std hardware and didn't like the way the adjusters were pushing on the axle. So I lengthened my stock adjusters and will be using those from the rear. Ill be welding on 1/8" plate on both sides top and bottom of the axle slot.
