Tim of DO THE TON
XS650 Junkie
Here's my situation.
I'm waiting on 2 oil seals for my bottom end (crank and countershaft).
Aside from that, I have everything I need to complete the engine build. Crank, endless cam chain, transmission are all in the case, just missing those two seals.
I'm thinking about putting a couple nuts on the bottom case, flipping the engine over and assembling the top end. Then turning it back over when I get the seals, pop off the bottom, put the seals in and Yamabond it shut.
Any reason to not do this? I can't think of anything. I wasn't going to torque the top end down till the bottom end was finished - just want to get things assembled and I have the weekend ahead of me.
The only thing I can think of is once the cam is on, the crank will be difficult to lift to get the seal on, but I'm pretty sure I'd be able to manage the one end of the crank to slide the seal in.
Thoughts? And out of curiosity, has anyone pulled the bottom end of an engine off while leaving the top end intact? In all my reading / forum perusing etc. I've not come across that scenario, say to replace seals, install a taller 5th gear etc.
