Are you pulling the head to replace the front cam chain guide?
If you are careful and don't break the seal on the base gasket when you lift the head, then you won't need to replace it.
If you might break the seal and not realize it until the engine is together and running and you find it leaking.
If your compression is good, then you can lift the jugs off, put on the new gasket, replace the jugs then put the head back on. This can be done without new rings, or even honing the cylinders.
If your compression isn't so good then I might pull the jugs, measure the piston to cylinder clearance to see if it needs anything.
With the jugs off you can measure the rods big end clearance and swing of the small end.
Your repair manual tells how to check these things.
