TwoJugs
Excess XS
Anbody using beehive valve springs on their motor?
There's a guy on E-bay selling them with retainers. The stock cams or any of the modified cams don't really call for such a spring. A R&D double spring is more than adequate plus the inner spring acts as a back-up in case the outer spring breaks.
I have R&D springs now. They are not giving me enough room. They advertise use for up to .460 lift. The cam I am using in this build has almost .510 lift at the retainer. I see Kibblewhite advertises they go .510. Also Webb cams have some listed that will work well over .500 lift. Just looking to see what beehives are being used and if they will give me the right specs to try in my build.
One of the issues I am hving with the titaniums is they have a ridge on the top that is much higher then everywhere else. The rockers hit on that ridge as you tighten down the rocker cover until a certain point where the rocker contacts the valve tip finally. It does put a dent, wear on the titanium retainer doing this, even removes some metal. The stocks are flat across, not a problem there. I see Comp Cams has a good page showing dimensions and specs on the springs they stock. Yes automotive aps but if the dimmension fit and the spring rates are simliar they should work. Pricing is good too.
These are the springs I plan to use in my next engine.
http://www.summitracing.com/parts/cca-26123-1/overview/
Steel Retainers
http://www.summitracing.com/parts/cca-799-1/overview/
Ti Retainers
http://www.summitracing.com/parts/cca-798-1/overview/
The Ti retainers aren't any lighter than the steel ones so it's probably not worth the added cost. A set of four beehive springs with steel retainers is only $80.
However, these are made for 7mm valve stems and probably won't work with 8mm valves. The added cost of 7mm guides and valves make it a spendy proposition if you can't make them yourself.
