We WANT to help but...........
Quit fluckin around, either tell us what you got, or go away. Again give us the stinkin numbers off the regulator, we will do the damn research and try to find out if it will work and how it needs to be wired. No one here can tell you how to wire up some random regulator to make YOUR bike charge correctly.
Uh you might not guess but my patience gets thin when we are all forced to play detective and you won't give us clues. It took three threads and 10 posts before we found out the regulator doesn't match the bike. Then I asked for the numbers you replied with a pic that I can't read the numbers from. Even if the regulator was good when you started, wiring it wrong MAY have fixed that. Really we wnat to help why are you making us work so hard? Electrical is not hard it just requires ORGANIZED thinking and the correct wiring of working components to function.
