So, I've had my bike tuned and running awesome for about a month. I actually work at a bike dealership (which actually means I have almost no time for my own bikes). It runs fantastic on the dyno and off, unless of course you need to stop. I cannot hit neutral and I cannot get the damn clutch to disengage so I can't even just clutch in at stops. I've adjusted and cleaned the worm gear. The Ball bearings are in there, I've even tried shim'ing the shift rod by adding a 3mm valve shim to the end and I still cannot get the damn thing to a point where I can ride it. I bought the hydraulic clutch conversion but the stupid clutch portion leaks even with new crush washers or o-rings so that conversion is out. I'm running out of riding season and ideas and I could really use the help.
