cleoncleon
Finally going to start a build thread; keep this project documented...
I'm going the Tracker route, Battery-less Hard-tailed tracker.
As of today, I acquired an engine <3 - 79' (2FO-XXXXXX).
- As of now, I'll be blasting her clean then tearing her down for checkup and 5th Overdrive install.
For the hardtail, I decided on going with a David Bird's hardtail.
I placed the order about a week ago with dimensions of ZERO drop and ZERO stretch. Going for a real compact/short bike, want it to look stocky and full as ever, yet boney.. With a tall 5 - 6" Solo Sattle and Pillion Pad in rear.
Going Mid or/ a slight rear set controls and a 2 into 1 pipe.
Tank wise, I'm shootin' for a Lowbrow Wassel Style P-Nut with a Deep tunnel, want it sitting low, not high like a bobber.
Fenders front AND back... lol I love fenders, man.
Going to Install:
17-32 Ratio
5th Gear Overdrive
PMA - (Banshee Parts Convert) + Sparks Capa.
Pamco - If I can afford it right away, PMA is a must though.
Luckily I got the Early XS set of Wheels with the High Shoulder Alumin. Rims and Drum Rear , that I'll run. More aesthetics will come as the build progresses.
Mainly time for cleaning and selling of current parts, got a ton of em' while scrounging around for a project.
Started on the carbs last night, they're pretty much good to go, still broken down for blasting the bodies clean.. I'll be getting a little 20lb Pressurized Blaster Pot/Tank for this project. Want to blast down the engine/carbs/ some stuffs and do some carbon cleaning in the head w/ it.
These carbs, not sure which they are, but they are so much easier to mess with than the ones on my XS750, seemed to be designed 'better'? I like where the jets sit in the bowl.. More places for things to get gummed up, but clean, seems sound...
Going to Install:
17-32 Ratio
5th Gear Overdrive
