Denisesewa
Been working on my 1980 street tracker project, I stripped all un-needed electricals and rewired the bike, no problem runs and acts as it should, then I shortened and adapted a set of KXL 650 USD forks to it, there wasnt a convenient location on or near the bars for the ignition switch so I moved it next to the starter relay and decided to just interrupt the main power from the relay with the ignition switch, just took it for a test ride to check out the new forks and when I went to shut it off with the key it kept running, using the kill switch on the bars killed it,( also turning the lights on with the key off also kills it) so I set about testing, with the key off there is no power to anything except the battery side of the starter relay and the positive side of the ignition switch.I started the bike, unplugged the ignition switch, bike keeps running, I then disconnected the battery after starting the bike and the bike keeps running.
Correct me if I'm wrong but doesnt an alternator need voltage to excite since its not permanent magnets?
Since the bike has a Mikesxs electronic ignition is it possible that it requires such a low voltage to operate the alternator is putting out trace current enough to run it since it dies if I turn on the lights with the key off?
I intend to rewire the ignition switch to also isolate the ignition when off ( which is how I wired it when the switch was @ the handlebars) which will solve the problem but still, I'm Baffled.
Enlighten me please .
